Filter by map extent not working with SQL Geometry
1438
03-30-2021 02:12 PM
MeleKoneya1
I have a dashboard that I was asked to filter by map extent.    It is not working even though I had set up the map actions to do so.
The data is stored in a SQL table (non Geodatabase) which seems to be the common denominator in the dashboards that are having this issue.
Is this a known issue with SQL data and dashboards?
Mele
jcarlson
How are the layers being brought into the map? If you're trying to work with them spatially, your best bet is to add a Feature service as opposed to a Map Image service.
- Josh Carlson
Kendall County GIS
MeleKoneya1
Josh,   Thanks for your response.   I am bringing the features in via an ArcGIS Server service from our onsite server.     I am using a feature layer.   Perhaps adding my URL in to a hosted feature layer, but do the trick.
