Filter based on sql Right expression
1467
07-31-2024 01:39 AM
KARIMLABIDI
Hello,
I'm trying to filter my layer to create a featureSet with a right but dashboard sends me a error .
My goal is to keep the features who have the same date as the actual year. I use the field DEVIATION and I hoped with a right do the query.
Here's my code
I've seen on esri documentation https://doc.arcgis.com/fr/drone2map/2023.1/help/sql-reference-for-elements-used-in-query-expressions... and my code seems good but it's doesn't work.
Thank you for your help!
jcarlson
The SQL functions in that page are not comprehensive. A lot depends on the underlying RDBMS, and there are many functions not on that list you can use, others on that list that don't always seem to work.
If you're trying to filter by year, and the year is always at the end of the string, try this:
var sizeFilter = `DEVIATION LIKE '%${Year(Now())}'`
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
KARIMLABIDI
Thank you it works!!!
