FeatureSet GroupBy CASE expression
1661
04-02-2024 09:47 PM
BlakeMorrison
I'm trying to write an SQL CASE expression for use within a FeatureSet/GroupBy function. I have a Date field that I'm grabbing using FeatureSetByPortalItem and I want to create a field that just puts the ages in classes.
Ideally, the dates would be dynamic as well, based on today's date and a defined age.
I'm pretty sure the indentation below is improper, but you get the idea of what I'm trying to achieve.
        expression: 'CASE
                       WHEN date_stat => 2020 THEN 1
                       ELSE date_stat => 2012 THEN 2
                       ELSE date_stat => 1984 THEN 3
                       ELSE date_stat => 1850 THEN 4
                       ELSE NULL
                      END',
        statistic: 'SUM'
Related to a previous post that I found the solution to: https://community.esri.com/t5/arcgis-dashboards-questions/data-too-big-for-a-featureset-calculation-...
BlakeMorrison
For those playing at home, the answer is:
        expression: 'CASE WHEN @today-date_stat < 1460 THEN 1 WHEN @today-date_stat < 4380 THEN 2 WHEN @today-date_stat < 14600 THEN 3 WHEN @today-date_stat > 14600 THEN 4 ELSE NULL END',
        statistic: 'SUM',
Note: Number of days is used to calculate the age. Ie. 1460 = 4x365
Note2: @today is a var, outside the GroupBy function, defined as Now()
BlakeMorrison
        statistic: 'SUM',
KenBuja
MVP Esteemed Contributor
You're not accounting for leap days. Four years has 1461 days, 12 years has 4383 days, and 40 years has 14610 days.
BlakeMorrison
haha
Thanks!
