Expression to count total from multiple layers
4885
12-21-2021 02:19 AM
SayedWali
I want to create an indicator to count items from multiple layers. Is there any arcade expression example or any reference? Any idea will be appreciated.
jcarlson
@SayedWali-  Just to recap and post the solution here, rather than in a private message:
var portal = Portal('https://npaid.maps.arcgis.com');
var FAR = FeatureSetByPortalItem(
    portal,
    '56db417ebbc541bcbb6ccf9c49524cc9',
    0,
    false
var PDIA = FeatureSetByPortalItem(
    portal,
    0,
    false
var total_count = Count(FAR) + Count(PDIA)
var outDict = {
    fields: [{ name: 'total', type: 'esriFieldTypeInteger'}],
    geometryType: '',
    features: [{attributes: {total: total_count}}],
// Return dictionary cast as a feature set
return FeatureSet(Text(outDict));
- Josh Carlson
Kendall County GIS
jcarlson
There are a number of examples on ESRI's Arcade expressions GitHub repo. Here's one that counts items from multiple layers for a chart:
https://github.com/Esri/arcade-expressions/blob/master/dashboard_data/CombineMultipleLayers(SerialCh...
If you haven't used a Data Expression before, they can look a lot more complicated than they really are. The linked example should apply just as easily to an Indicator widget.
- Josh Carlson
Kendall County GIS
jcarlson
    portal,
    0,
    false
    portal,
    0,
    false
var outDict = {
    geometryType: '',
- Josh Carlson
Kendall County GIS
SayedWali
Hi @jcarlson , Thank you very much!
SayedWali
@jcarlson , one more question, from the two layers, I want to get a shared field as a long list. For example, I want to have a list of all object IDs from both layers. any idea to edit the expression?
