Embedded Survey on Dashboard Date US not UK
697
11-30-2020 02:11 AM
MartynStringer
Hello,
I have an embedded S123 survey on an operations dashboard and it is set in edit mode to allow the user to update records via the dashboard. I am in the UK and all settings in the browser are set to UK but the date fields in the embedded form are showing as m/d/yyyy. Is there any way to change this to UK date format dd/mm/yyyy?
I have configured the pop up for the survey feature layer to show UK format and when using the survey on a mobile device it also displays the UK format.
I hope I am not missing something obvious, any help would be greatly appreciated.
Martyn
Tags (1)
