Does ArcGIS Dashboards allow to time enabled slider maps in Map Viewer?
6237
06-13-2023 03:53 PM
AndrewCastilloTBSL
Do Dashboards allow time-enabled sliders from your maps like in Map Viewer?
DanielFox1
Hi @AndrewCastilloTBSL
I have just had a look at Dashboards and have found this setting (see screenshot attached). This was using a Living Atlas layer but I am unable to see any of the time slider functionality as there is in Map Viewer, unfortunately.
In the community post below it is said to be unsupported at this time:
Time Slider Widget in Operations Dashboard
However, there is an option outlined in the following community post where you might be able to manipulate/amend the URL parameters:
On Dashboard and time-enabled maps
AndrewCastilloTBSL
I see, hopefully, they do add this in the future. thanks
MappyIan
I could do with this functionality too.  There is an Idea posted for it here, please add your comments/kudos to this Idea, then hopefully one day it may  get implemented: https://community.esri.com/t5/arcgis-dashboards-ideas/time-slider-widget-for-operations-dashboard/id...
