Does anyone know if there is a swipe function for maps on Dashboard
2036
12-09-2021 11:43 AM
hannahggarcia
I have a set of stacked maps that I was hoping I can use a swipe function for on a Dashboard. Does anyone know if this is a possible function to do on a Dashboard?
jcarlson
Not in Dashboards, unfortunately. The only place you can use Swipe is Web App Builder or one of the configurable apps like Compare.
- Josh Carlson
Kendall County GIS
Kanin
by Esri Contributor
As a workaround, I would suggest creating a web app with the Swipe widget in ArcGIS Web AppBuilder and embed that app into your dashboard.
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
