Division operator not working in Arcade Expression
1766
03-17-2025 08:50 AM
ScottFortman1
Hi there community!
I am really hoping for some help on this, it is driving me mad!  I have an Arcade script being used in an indicator widget in a dashboard on10.9.1 Portal and works great.  I am migrating same dashboard and widget to 11.3.1.  I copied the original script to new dashboard, changed the Portal location, service id, layer id, and the fields I pull in are identical.  The script is just doing a Groupby function to create a table with a handful of existing fields plus two new fields that are calculated.  The first one is using a multiply math operator and works fine.  The second expression is using division and I get a "Test execution error: Unknown Error. Verify test data.
I have commented out the second expression and the script works, so I know it is good up to there.  If I change the division operator to addition, subtraction, or multiplication, it also works, just not the value I need.
Any help or thoughts are greatly appreciated, Thanks!
Script where second expression doesn't work:
var tvwdportal = Portal('https://acadia.tvwd.org/portal')
var flush = FeatureSetByPortalItem(tvwdportal,"4159ad26944145339b8ae97ea484c331",70,['Duration', 'EstimatedFlushTime', 'Turbidity','StartTime', 'StopTime','assetid'],true)
groupby(
    flush,
    ["StopTime", "assetid", "Turbidity","EstimatedFlushTime", "Duration",
    {name:'EstimatedTimex2', expression: 'EstimatedFlushTime * 2', statistic: 'MAX'},
    {name: 'PipeVolumeTurnover', expression: 'Duration / EstimatedFlushTime', statistic: 'SUM'}
Script and table if I change operator on second expression (Line11)
groupby(
    flush,
    {name: 'PipeVolumeTurnover', expression: 'Duration * EstimatedFlushTime', statistic: 'SUM'}
StopTime assetid Turbidity EstimatedFlushTime Duration EstimatedTimex2 PipeVolumeTurnover ROW__ID
null"FLSH105902"nullnullnullnullnull149875
null"FLSH105911"121.902975636043.8059511314.178538150675
null"FLSH105985"1.544.23492962308.469859127.047889159472
null"FLSH105987"nullnullnullnullnull159872
null"FLSH106037"nullnullnullnullnull165475
null"FLSH106067"nullnullnullnullnull167875
CodyPatterson
MVP Regular Contributor
Hey @ScottFortman1
Great to hear you got it! So strange that || works but && doesn't just how Arcade and JavaScript differ! Here's a corrected one from the above, even though you got it all checked out:
IIF(!IsEmpty(EstimatedFlushTime) AND EstimatedFlushTime > 0, Duration / EstimatedFlushTime, 0)
Cody
CodyPatterson
Hey @ScottFortman1
This usually happens if there's a chance that the value could be NULL or 0, which cannot be calculated, use this here instead:
{name: 'PipeVolumeTurnover', expression: 'IIF(!IsEmpty(EstimatedFlushTime) && EstimatedFlushTime > 0, Duration / EstimatedFlushTime, 0)', statistic: 'SUM'}
If it's greater than 0, it should work out for you! Edited for null avoidance too.
Cody
ScottFortman1
Thanks for reply, Cody.  I pasted that in and I still got this:
Test execution error: Expected "!=", ")", "*", "+", ",", "-", "/", "<", "<=", "<>", "=", ">", ">=", "AND", "BETWEEN", "IN", "IS", "LIKE", "NOT", "OR", "||", or [ \t\n\r] but "&" found.. Verify test data.
So I actually ran a filter at the feature set definition and that fixed my original expression.  The insight on the null or 0 values was a huge help though.
CodyPatterson
Hey @ScottFortman1
Cody
