I am trying to add some text and then a field name to the top text of an indicator. Any suggestions on how to make that happen? The field name is {NAME}.
Top Text: Uninsured Population (estimate) for Bedford County
Does it matter if this indicator is tied to a category selector? Will the name populate based on the county selection?
If your indicator is configured to show per-feature, then you should be able to call attributes directly.
And in advanced formatting:
