Dephased data in map using date selector
607
03-07-2023 04:37 PM
EduardoDiaz
Hello everyone I have an issue with the point data that is displayed on my dashboard. The Dashboard's source map use a referenced layer three times, each one with different Definition Query and simbology, the layers are "Last 60 minutes", "Today" and "Yesterday", the querys was edited on Pro 3.1 adding and opening the map from Portal. The Enterprise versión is 11.
In Pro the data is six hours behind compared to data in Enterprise, when I loaded the original data to Portal I shared it as Web Map and seted the correct Time Zone.
Query example:
Yesterday - Start_Date<= CURRENT_TIMESTAMP() AND Start_Date >= CURRENT_TIMESTAMP()-2
(Works fine)
The Dashboard categories for Date Selector are "Last hour", "Today", "Yesterday" and use the relative periods from defined options, Today for Today, Yesterday for Yesterday, etc.
The problem is that the points showed when the date selector is actioned are from two different layers (half-and-half) but are correct for the period (Date Selector Period).
The idea is use the Date Selector Period over the Layers and get the same data.
Wich could be the issue?
