Date Selector in Operations Dashboard for ArcGIS
2515
11-12-2018 10:49 PM
AndrewJohnston
I've added a date selector/filter to my AGOL operations dashboard to show results from Survey123 forms. This data selector is great filtering data displayed in the map. However, is there a way to link the date selector to filter data shown in lists so that the map and lists update at the same time?
DerekLaw
Esri Esteemed Contributor
Hi Andrew,
> ... is there a way to link the date selector to filter data shown in lists so that the map and lists update at the same time?
Yes, this should be possible. All you need to do is simply configure your date selector and add another Target for your filter action ... in this case, your List element. I've added an example screenshot below:
Hope this helps,
