Data Expressions and Access Permissions
2251
07-12-2022 12:04 PM
JoshuaFlickinger
I have a dashboard utilizing data expressions to summarize some field survey data on the fly.  The expressions work for everyone with whom the dashboard is shared - as long as they're in my organization.  Outside the organization, the elements referencing the data expressions have a "Data Source Error" message.  I'm wondering if this has to do with how I'm pulling the data in as a FeatureSetByPortalItem, i.e.
// Set portal and layers
var portal = Portal('your portal URL');
var fs = FeatureSetByPortalItem(
    portal,
    'itemID of service',
    layer index,
    ['list', 'of', 'fields'],
    false
Is calling in the data through my portal preventing users outside my portal from accessing the data, even though they have access via a share group?  If so, is there another way to call in the data so that they maintain access?  Can't seem to figure out another reason these elements would fail.  Everyone in the share group has access to all feature layers, web maps, and the dashboard itself.
Josh
JoshuaFlickinger
For anyone else stumbling upon this problem in the future, I was able to troubleshoot the issue.  The problem was solved by changing the portal URL in line 1 to the 'plain jane' ArcGIS Online (as opposed to our organization's modified URL for ArcGIS Online).
var portal = Portal("https://www.arcgis.com")
JoshuaFlickinger
HollyTorpey_LSA
Thank you so much for posting the solution you found! You just saved me hours of frustration. 😍
- Holly
SaranehSFitzgerald
Hi Joshua, if you changed the portal variable to www.arcgis.com, then how were you able to access the layer that lives within your organizations portal? Was your layer shared to the public or was it private?
