Data expression to pull out most recent survey results
749
11-11-2021 03:33 AM
KatieQuantrell
I am trying to create a data expression to pull out a dataset that just contains the most recent survey results for several survey stations at various locations. My main feature layer contains fields for location ("Location", string), survey station id ("StationID" field, string), survey date ("SurveyDate" field, date) and survey result ("CheckResults", string (either 'Positive' or 'Negative')).
This is similar to a previous query raised on this forum "Data Expressions using GroupBy and Filter" but the solution to this doesn't work in this case unfortunately as all survey stations aren't necessary surveyed on the same day each time. So the most recent record for station A1 may have a different date to the most recent record for station A2 for example.
An example of my data is shown below:
Location
StationID
SurveyDate
CheckResults
A
A1
01/10/2019
Negative
A
A2
12/09/2021
Positive
A
A3
05/06/2021
Negative
B
B1
05/06/2021
Positive
B
B2
28/06/2020
Negative
A
A1
22/10/2016
Negative
A
A2
15/09/2020
Negative
A
A3
03/05/2019
Positive
B
B1
04/05/2019
Negative
B
B1
06/04/2018
Positive
What I would like to return:
Location
StationID
SurveyDate
CheckResults
A
A1
01/10/2019
Negative
A
A2
12/09/2021
Positive
A
A3
05/06/2021
Negative
B
B1
05/06/2021
Positive
B
B2
28/06/2020
Negative
Any help on how to do this would be really appreciated.
Many thanks,
