Dashboard Popups
1867
07-29-2021 10:45 AM
AtilanaMercado
I am trying to hide certain attribute fields in the pop ups of my dashboard view. The only option i see for popups is to turn it on or off. How to i edit what attribute fields show?
jcarlson
The popup fields are based on whatever map is being referenced in your dashboard, and field visibility needs to be adjusted there.
If you are referencing a layer directly, and not a web map, it will use whatever the default visibility is for the layer, as defined in the layer's visualization page.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
temprobertcottreau131313
go to your web map in AGOL and click on Configure Popups to remove the fields you don't want to show.  this will reflect in your dashboard
