Dashboard, Map Selection, Multiple Layers
4909
09-28-2022 03:45 PM
JordanBalti
I have a Dashboard that the user wants to make selections per the map. There are 5 different layers on the map with indicators and elements for each that update with filters/selectors. When you select on the map it gives you the choice of which layer to select. Then disappears after you've made a single selection. Is there a way to have them all be selected without redoing your lasso/rectangle?
FriederikeAlschner
This was solved with the June 2023 release of dashboards.
For more details see this blog post
GarrettMelvin
Adding reply to express support for this request.  We have a map with two geoevent layers and two corresponding lists.  Would like to have one map selection to filter both lists in the dashboard.
NormBetland
I would really like this feature to be added. My map has 5 layers. It would be very useful to not have to do the lasso 5 times. Considering that each time it is done it adds it to the same selection anyways, this would be very helpful.
FriederikeAlschner
