Dashboard map not showing all features, even when filtered.
15116
22
10-14-2020 10:30 AM
by Anonymous User
Not applicable
I have a dashboard that contains one large-ish polygon feature class (20,000 records). I have a filter for year and another filter for another element.
The filters have an action on the features so they reduce the number the map has to display. No matter how few features there are, the map always refuses to show all features at the full extent. It is acting as if there is a series of scale dependencies or too many features to display, neither of which is the case.
It gets a bit weirder. If I filter the features in the web map that feeds the dashboard for a particular year, ALL FEATURES FOR THAT YEAR WILL DISPLAY AT FULL EXTENT IN THE DASHBOARD (pardon the all caps).
If I do not filter in the web map, but apply a filter in the dashboard, only a subset of features displays at full extent, with more features appearing as you zoom in.
I have set maximum number of records to return on the service at 100,000.
This appears to be a bug.
Has anyone experienced this? I would very much appreciate some advice as we are currently stuck.
Thank you,
Randy McGregor
danheim
hello everyone.
I'm not quite sure, but check whether you have activated the update interval of the level to be displayed and set it to 1 minute as a test.
I have similar problems with the display of the point data and tried around with the refresh interval and it seemed like it is now displaying the data correctly in the dashboard. Previously, these were completely invisible to me, regardless of my zoom status.
Best regards
DanteLee
Holy moly, that is such a bizarre workaround. Thanks for chiming in. That did the trick for me too.
PanGIS
Amazing!
This solved the issue to me as well!
@Anonymous User  check this out.
by Anonymous User
Not applicable
Thank you for the suggestion. Will do.
by Anonymous User
Not applicable
Sorry I didn't see this when you posted it. I will give this a try. Thanks!
by Anonymous User
Not applicable
I'm not familiar with this setting. Where does one change it?
Thank you,
Randy
danheim
DanteLee
by Anonymous User
Not applicable
Got it. Testing (So excited!)
by Anonymous User
Not applicable
Yes! It worked. Thank you!🎉
