Dashboard Lists - Change displayed field
1473
07-13-2023 07:34 AM
AlexBuechner
I made a dashboard to keep try of sewer pipes cleaned.  I wanted to list them out by the field for pipe ID, but instead it shows a different feild.  I don't see where i can change it.  I'll post the screenshot below.  I want the Pipe ID feild to replace where it says "true" on the list.
JenniferAcunto
I do not see any screenshots, so I'm assuming there's nothing unusual happening...
You can use the curly brackets to select fields in your data to display, or if you know the field name you can simply type it directly into the text editor inside curly brackets {fieldname}. Simply delete the default field if you don't want to display it.
- Jen
JenniferAcunto
- Jen
