Dashboard/Indicator and Arcade
3268
01-19-2022 09:13 AM
by Anonymous User
Not applicable
Background - using Dashboard and the indicator widget.  When the widget has no data, the return is no data. Instead I would like to return a zero, "0".  Now with Arcade ability, I thought I might be able to do this, but need your help.  Here is what I have tried.
Using the below, I get "Unexpected Token If".  I wonder if this is because "If" is not listed in the function list.
return {
//textColor:'',
//backgroundColor:'',
topText: If ($datapoint["sum_number_of_citations_issued"] > '0'){
return '$datapoint["sum_number_of_citations_issued"]';
} else if ($datapoint["sum_number_of_citations_issued"] < '0'){
return '0';
topTextColor: '#ffffff',
topTextOutlineColor: '',
topTextMaxSize: 'medium',
//middleText: '',
//middleTextColor: '',
//middleTextOutlineColor: '',
//middleTextMaxSize: 'large',
//bottomText: '',
//bottomTextColor: '',
//bottomTextOutlineColor: '',
//bottomTextMaxSize: 'medium',
//iconName:'',
//iconAlign:'left',
//iconColor:'',
//iconOutlineColor:'',
//noValue:false,
//attributes: {
//attribute1: '',
// attribute2: ''
I also tried:
IIf($datapoint["sum_number_of_citations_issued"] < 1, '0')
and the error I get is Syntax Error: Function signature does not match; IIF
Thank you,
Annette
JayantaPoddar
Just try
For No Data value, just change the Default Label to 0.
Think Location
JayantaPoddar
Check if the following expression works.
var s = $datapoint["sum_number_of_citations_issued"]
IIF(s < 1, 0, s)
Think Location
by Anonymous User
Not applicable
Hello,
States unexpected token var.  Am I putting it in the wrong place. This is the indicator widget on dashboard.  I then removed it and placed the two lines at the top, but I wasn't sure what to put after topText: .
Thank you for your help.
return {
//textColor:'',
topText: var s = $datapoint["sum_number_of_citations_issued"]
IIF(s < 1, 0, s)
//middleText: '',
//bottomText: '',
//iconName:'',
//iconAlign:'left',
//iconColor:'',
//noValue:false,
//attributes: {
// attribute1: '',
// attribute2: ''
JayantaPoddar
Just try
Think Location
by Anonymous User
Not applicable
Thank you so much! Is this a new feature with 10.9.1 or have I been blind! So easy. I knew it had to be. Thank you, thank you!
NunoFarinha
This solution has a limitation. If the backgroundColor property is being used to define a specific color for the indicator's background, there doesn't seem to be a way to display the No Data label and keep the indicator's background color. When the no data label is displayed, the indicator color will also change to the "element background color" defined on the dashboard's theme, which is not ideal.
