Dashboard Edit - "failed to calculate value"
420
03-12-2025 08:04 AM
DerekBernard
I created a web map and setup a form with a calculated field (grab property address from nearest parcel).  It works in the web map and works in the Experience Builder App I built.  But in the Dashboard I get the error "Failed to calculate value."
FORM Code:
var searchDist = 100;
    var addresses = Intersects(FeatureSetByName($map, "City Parcels"), Buffer( $feature, searchDist, "feet"));
    var nearestaddress;
    var min_dist = 150;
    for (var f in addresses){
        var addressDist = Round(Distance(f, $feature, "feet"),2);
        if (addressDist < min_dist) {
            nearestaddress = f.PROP_ADD1;
            min_dist = addressDist;
    return nearestaddress;
I guess it might be a little more complicated because this field is only editable if another field is switched on.
Any ideas?
CodyPatterson
MVP Regular Contributor
Hey @DerekBernard
I'm curious if it would be possible to use something instead of FeatureSetByName, something like FeatureSetByPortalItem perhaps, this may be able to get this sorted as the variables may not be able to be accessed. Here is the documentation here: https://developers.arcgis.com/arcade/function-reference/portal_functions/#featuresetbyportalitem
Cody
DerekBernard
I tried changing the line and it doesn't work.  I might not be using the function correctly.
    var addresses = Intersects(FeatureSetByPortalItem(Portal('https://arcgis.co.beltrami.mn.us/'),'9c473ed759734b9a9a5799a8c20f9e39',0,['*'],true), Buffer( $feature, searchDist, "feet"));
CodyPatterson
Hey @DerekBernard
Pretty close! This is more what I had in mind here:
var portal = Portal('https://arcgis.co.beltrami.mn.us/');
var parcels = FeatureSetByPortalItem(
    portal,
    0,
    ['PROP_ADD1'],
    false
var addresses = Intersects(parcels, Buffer($feature, searchDist, "feet"));
var nearestaddress;
var min_dist = 150;
for (var f in addresses) {
    var addressDist = Round(Distance(f, $feature, "feet"), 2);
Give this a shot and let me know if it's up and going!
Cody
DerekBernard
I can't get this to work in just the web map even.  Maybe I have my portal or item id wrong.  Do you know how to confirm those?
