Dashboard Date Selector with wrong time
1692
05-17-2022 01:53 PM
RoseZhou2
I have a dashboard with a Date Selector (type=Advanced). Please see the screenshot below.
When select "Past 14 days", from web browser's Developer's tool, I found it queried the date range more than 14 days. For example if I select it at  4:45 pm EST, May 17th, the "where" clause is:
date <=timestamp '2022-05-17 21:45:10' AND date >=timestamp '202-05-03 04:00:00'
It's more than 14 days! I have another web map with filer set: 'date in the last 2 weeks'.  This web map queries exactly 14 days, from date <=timestamp '2022-05-17 21:45:10' AND date >=timestamp '202-05-03 21:45:10'.
The dashboard and the web map return different result due to different query time period. How to make those two consistent?
Rose
RoseZhou2
For those may encounter the same issue, I have found a solution.
In the feature layer within the web map, I used following definition query before:
date BETWEEN CURRENT_TIMESTAMP - INTERVAL '14' DAY AND CURRENT_TIMESTAMP
After I changed to following, it’s working:
date BETWEEN CURRENT_DATE - INTERVAL '14' DAY AND CURRENT_TIMESTAMP
Rose
RoseZhou2
By the way, I am using ArcGIS Enterprise version 10.8.1 Portal built-in dashboard.
Rose
RoseZhou2
Rose
