Dashboard data Expression returns null featureset
1045
06-12-2025 12:25 PM
SamBelisleLID1990
I am trying to create a dashboard gauge to show percentage of time passed in a season. So, if the season runs from 1 July to 30 September, then on 23 July, the gauge should read 25%.
I want the FeatureSet to show the percentage in the 'DayPercentage' field for the gauge.
My Arcade code to do so is as follows:
var ThisYear = Number(Year(Now()));
//var ThisMonth = Month(Now());
//var ThisDay = Day(Now())
var startDate = Number(Date(ThisYear,7,1));
var endDate = Number(Date(ThisYear,9,30));
var currentDate = Number(Date(ThisYear, 7, 25));
var Season = Number(DateDiff(endDate,startDate))
var SeasonSoFar = Number(DateDiff(currentDate,startDate))
var SeasonPerc = Number((SeasonSoFar/Season)*100);
var features = [];
Push(features, SeasonPerc)
var PercDict = {
  'fields': [
    {'name':'DayPercentage','type':'esriFieldTypeInteger'}
  'features': features
var features2 = FeatureSet(PercDict);
return features2
This returns a null dataset. I've tried formatting the Dictionary differently, formatting the FeatureSet differently, using Push to get the data through in different places and formats, and I'm stuck. What am I doing wrong?
KenBuja
MVP Esteemed Contributor
There were a couple of things that needed changing.
  • The dates are incorrect if you're portraying 1 July through 30 Sept. In the Date function, months are 0-based, so July is 6, not 7 (lines 5, 6, and 7)
  • The SeasonPerc was a NaN since you were converting the Dates to numbers (lines 5, 6, and 7). The DateDiff function needs Dates as input, not the converted number.
  • DateDiff also returns a number, so there's no need to convert it (lines 9 and 10)
  • SeasonPerc has to be an integer if you're putting it into a integer field (line 11). If it's not converted (and Arcade will not convert it for you), that field attribute will be null.
  • You have to push a dictionary object containing the "attributes" key into the features array (line 15)
var ThisYear = Year(Now());
var startDate = Date(ThisYear, 6, 1);
var endDate = Date(ThisYear, 8, 30);
var currentDate = Date(ThisYear, 6, 25);
var Season = DateDiff(endDate, startDate);
var SeasonSoFar = DateDiff(currentDate, startDate);
var SeasonPerc = Round(Number(SeasonSoFar / Season * 100));
var features = [];
Push(features, { attributes: { DayPercentage: SeasonPerc } });
var PercDict = {
  fields: [{ name: "DayPercentage", type: "esriFieldTypeInteger" }],
  features: features
return features2;
KenBuja
var features = [];
var PercDict = {
  features: features
return features2;
SamBelisleLID1990
Thank you so much!
Many of those changes were things I had actually done correctly the first time but had changed in all my attempts to fix this. The push with attributes was the missing piece.
KenBuja
Glad to help. Please check the "Accept as Solution" box to help others searching on this problem
