Create a Table with Inspection Year and Count based on Date Field
360
06-04-2025 07:51 AM
MattStevens2
I'm trying to create a table that looks like the table below based on a date field called Inspect_Date. I just want to extract the year from the record and then have a count of those records. It would look like below.
I know the arcade code to pull the layer data and then code to turn it into a dictionary. Where I'm struggling is turning that dictionary into the table below.
Inspection YearInspection Count
2024442
20258
Code so far after getting the data:
var yearCounts = {}
// Count inspections by year
for (var f in fs) {
    var inspDate = f["Inspect_Date"]
    if (!IsEmpty(inspDate)) {
        var year_1 = Text(Year(inspDate))
        if (HasKey(yearCounts, year_1)) {
            yearCounts[year_1] += 1
        } else {
            yearCounts[year_1] = 1
// Construct output features using Feature()
var features = []
for (var y in yearCounts) {
    var attrs = {
        "Year": y,
        "Inspection_Count": yearCounts[y]
    Push(features, Feature(attrs))
// Return a proper FeatureSet
var schem = {
    fields: [
        { name: "Year", type: "esriFieldTypeString" },
        { name: "Inspection_Count", type: "esriFieldTypeInteger" }
    geometryType: "",
    features: features
return FeatureSet(schem)
KenBuja
MVP Esteemed Contributor
You just need to make a minor change on line 23
var yearCounts = {}
for (var f in fs) {
        } else {
var features = []
    var attrs = {
        "Year": y,
    Push(features, {attributes: attrs})
var schem = {
    fields: [
    geometryType: "",
    features: features
KenBuja
var yearCounts = {}
for (var f in fs) {
        } else {
var features = []
    var attrs = {
        "Year": y,
var schem = {
    fields: [
    geometryType: "",
    features: features
MattStevens2
Thank you!!!
