combine datasources to feed widget
977
09-19-2016 11:25 PM
AlistairFox
My use case is that I have data collected that is split by collectors in survey123 so the result is 2 seperate feature classes with the same schema.
Can I look at the combined results in widgets in Ops Dashboard without physically merging them into one feature class.
Eg: I want to create a bar chat that looks at both feature classes in my map but it will only let me select 1, hence I get a chart with data from 1 not the combined 2. Don't really want to have to manage a merge update process ongoing and yes, they do need to be collected at this split level from Survey123 🙂
Tags (3)
