Category Selector... help!
551
11-17-2025 01:11 PM
KarenHall
I'm trying to filter this layer so that when I select a project name, only the parcels specific to that project name are visible.
I've made it to the category action tab, but I'm lost on what a source field and target field are for.
I've attached a picture if that helps to clarify what I'm referring to.
Neal_t_k
MVP Regular Contributor
Those are your matching fields, the fields you are basing your relationship on.  So for example you have two tables: ProjectName and Parcels
ProjectName:
Name,  ParcelNumber
Pr1,  001
Pr1, 002
Pr2, 003
Pr2, 004
Parcel:
ParNum
001
002
003
004
So, the source field you would put "ParcelNumber" and in target you would put "ParNum"
