Dear All,
Is there any way of installing Operation Dashboard on a windows 7 Machine. I am getting the following error when i try to install the application.
PLATFORM VERSION INFO
Windows : 6.1.7601.65536 (Win32NT)
Common Language Runtime : 4.0.30319.296
System.Deployment.dll : 4.0.30319.1 (RTMRel.030319-0100)
clr.dll : 4.0.30319.296 (RTMGDR.030319-2900)
dfdll.dll : 4.0.30319.1 (RTMRel.030319-0100)
dfshim.dll : 4.0.31106.0 (Main.031106-0000)
IDENTITIES
Deployment Identity : Operations Dashboard.app, Version=10.3.0.825, Culture=neutral, PublicKeyToken=f464941b06bea132, processorArchitecture=msil
Application Identity : Operations Dashboard.exe, Version=10.3.0.825, Culture=neutral, PublicKeyToken=f464941b06bea132, processorArchitecture=msil, type=win32
APPLICATION SUMMARY
* Installable application.
* Trust url parameter is set.
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of C:\Users\max5\Desktop\RWANDA DATA\OperationsDashboard (7).application resulted in exception. Following failure messages were detected:
+ Failed to load the runtime. (Exception from HRESULT: 0x80131700)
ERROR DETAILS
Following errors were detected during this operation.
* [5/7/2015 1:18:27 PM] System.Runtime.InteropServices.COMException
- Failed to load the runtime. (Exception from HRESULT: 0x80131700)
- Source: System.Deployment
- Stack trace:
at System.Deployment.Application.NativeMethods.GetRequestedRuntimeInfo(String pExe, String pwszVersion, String pConfigurationFile, UInt32 startupFlags, UInt32 runtimeInfoFlags, StringBuilder pDirectory, UInt32 dwDirectory, UInt32& dwDirectoryLength, StringBuilder pVersion, UInt32 cchBuffer, UInt32& dwLength)
at System.Deployment.Application.Win32InterOp.SystemUtils.CheckSupportedImageAndCLRVersions(String path)
at System.Deployment.Application.SubscriptionStore.CheckApplicationPayload(CommitApplicationParams commitParams)
at System.Deployment.Application.SubscriptionStore.CommitApplication(SubscriptionState& subState, CommitApplicationParams commitParams)
at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
