Can you create a category selector that filters across multiple fields?
3035
02-19-2019 08:15 AM
shildebrand
I am trying to create a category selector that filters records across multiple fields.  For example, the drop down for the selector would include multiple work order categories such as:
Cannot Locate (CANNOT_LOCATE = 'YES')
Covered Over (COVERED_OVER = 'YES')
Damaged Structure (STRUCTURE_CONDITION = 'DAMAGED')
Each one of these categories has it's own definition query, but each queries a separate field in the same feature service.  Ideally, each time the user selects a category from the drop down list, the application would filter/display those records on the map and provide a count of them in an indicator.  Does anyone have any examples out there that do something similar?  Does the dashboard provide functionality to do this?
Thanks!
AndrewHargreaves2
Hi Operations Dashboard for ArcGIS‌ team
I'd like to do this too. I thought I was close by using the "Defined Values'' option within a Category Selector. However, I can actually only apply that defined value to a single layer and a single field within that layer. As Samuel Hildebrand‌ asks for above, the ability to query across more than a single field would be welcomed.
Derek Law
