Can't see dates in browser view
4534
7
02-18-2016 05:32 AM
Real_EstateDepartment
Web Browser Dashboard- Google Chrome Version 48.0.2564.109 m
But I can see them in desktop View
Any ideas on how to fix this?
Thanks
JakeSkinner
Esri Esteemed Contributor
What type of widget are you using?  After a quick test, I'm having trouble reproducing this issue.
I am using the list widget
Can see all dates in desktop
But in Browser view, I can only see create date and edit date not start and expired dates that I built
ChristopherOlsen
How were the fields created and where does the data come from?  Is this a feature class from AGOL or ArcGIS Server?  If you bring in the data as an external data source and hook up the list widget, can you reproduce?
Chris
I created the fields in AGOL after building the dashboard application.
The only way I found to fix the problem was to override the feature class in AGOL with a downloaded copy of the feature class using ArcMap 10.3.1
ChristopherOlsen
I'm still looking into this issue.  Haven't been able to reproduce yet, but still testing.
ChristopherOlsen
I was able to reproduce the issue with some test data.  I've logged the issue with our team and we will look for a solution. Thanks!
Chris
AndrewCallison
Thanks Chris!
