Basemap Switcher in Dashboards
1028
12-11-2025 04:18 PM
AdmininstratorRDOS
I have a dashboard built in Enterprise 11.5 that's doing odd things when switching basemaps.
When you go to switch basemaps on a map embedded in the dashboard, the panel expands with whitespace to the right of the basemap panel, obscuring the map.
Sometimes this happens the first time you switch the basemap, sometimes its the fourth time. Tried with different some webmaps/dashboard settings/arrangements of elements but same behaviour.
First time clicking on basemap switcher, looks normal.
Second time clicking on basemap switcher. Panel expands with white space to the right of it.
When you click exit on the basemap panel, the white space remains. If you have element re-sizing enabled, you can sorta get rid of it by resizing the panel of an element to 'wipe' it off.
Anyone else encountered this? Any solutions? Thanks!!
MikeOtillio
I am having the same issue.  Seems to have started a few months ago.  You described what is happening perfectly.  I can't find the pattern to what is causing the issue, but there definitely is an issue.
JessNewton1
We Have exactly the same problem and it occurred when we upgraded to Enterprise 11.5
Menno_ter_Bals
Same issue here after upgrading to 11.5.
ad353547
Have been experiencing this for awhile and relieved it's not just me. This is an annoying glitch that seems like should have a simple fix.
