Arcade Expression in Dashboard runs in testing, then Unable to execute Arcade script appears
11322
23
06-12-2024 11:29 AM
RichardCreek
Hello Community,
I am trying to determine why this arcade expression runs during testing, but then when I click "done" and go back to the "Select a layer" page to select the expression to use in a bar chart the data expression text is grayed out with an alert saying "Unable to execute Arcade script".
I've included my script below for reference, I would appreciate any assistance or explanation why this isn;t working as intended.
// sets portal url
var cobportal = Portal('https://bloomingtonin.maps.arcgis.com/');
// assign Crash Dataset variables
var crashDatasetID = '50b2634c8c9443f58cd004f1138ef7ea';var crashLayerID = 0;
// assign FeatureSet variables
var crashFs = FeatureSetByPortalItem(cobportal, crashDatasetID, crashLayerID, ['number_dead', 'gis_incapacitating'], true);
// Initialize counters
var totalDeaths = 0;var totalInjuries = 0;
// Iterate through the FeatureSet and calculate totals
for (var crash in crashFs) {
  if (IsEmpty(crash.number_dead) == false && crash.number_dead > 0) {
    totalDeaths += crash.number_dead;
    if (IsEmpty(crash.gis_incapacitating) == false && crash.gis_incapacitating == 'Yes') {
      totalInjuries += 1;
// Return the results as an array
return [totalDeaths, totalInjuries];
KenBuja
MVP Esteemed Contributor
Since I don't have access to your data, I've been using another dataset to do my testing. This version returns the expected FeatureSet. Can you modify it to use your data?
function Memorize(fs) {
  var fieldList = Schema(fs)['fields'];
  Push(fieldList, {"alias":"Collision Year","editable":true,"length":4,"name":"collision_year","nullable":true,"type":"esriFieldTypeInteger"})
  var temp_dict = {
    fields: fieldList,
    geometryType: '',
    features: []
  for (var f in fs) {
    var attrs = {}
    for (var attr in f) {
      attrs[attr] = f[attr]
    attrs['collision_year'] = Year(f['date'])
    Push(
      temp_dict['features'],
      {attributes: attrs}
  return FeatureSet(Text(temp_dict))
}// Fetches features from a public portal item
var fs = FeatureSetByPortalItem(
  Portal("https://www.arcgis.com"),
  // portal item id
  "25e36eb0d93d49859f73a4c98b1d3484",
  0, // layer id
  ["*"], // fields to include
  false // include or exclude geometry
var newFS = Memorize(fs)
var summaryFS = GroupBy(newFS, 'collision_year',
    {name: 'Maximum magnitude', expression: 'magnitude', statistic: 'Max' }
return summaryFS;
RichardCreek
Ken if you could provide some additional assistance I'd really appreciate it, still stuck.
This is what I have now, but it's not correct:
// sets portal url
  var fieldList = Schema(fs)['collision_date'];
  var temp_dict = {
    fields: fieldList,
    geometryType: '',
    features: []
    for (var f in fs) {
    var attrs = {}
    Push(
      {attributes: attrs}
return FeatureSet(theDict);
return summaryFS;
KenBuja
When posting code, use the "Insert/Edit code sample" button. It makes your code easier to read and provide line numbers in your code.
Remember that I was using a different data set to show you how it would work, since I couldn't test it with your data and you were getting an execution error.
Do you still get that error when using this?
    {name: 'number_dead', expression: 'TotalDeaths', statistic: 'SUM' },
    {name: 'gis_incapacitating', expression: 'TotalInjuries', statistic: 'SUM' }
RichardCreek
// sets portal url
var crashFs = FeatureSetByPortalItem(cobportal, crashDatasetID, crashLayerID, ['number_dead', 'gis_incapacitating', 'collision_date'], true);
var summaryFS = GroupBy(newFS, 'collision_date',
Like this? it does not execute
KenBuja
Try this
**Updated GroupBy expression
// sets portal url
  var temp_dict = {
    fields: fieldList,
    geometryType: '',
    features: []
    for (var f in fs) {
    var attrs = {}
    Push(
      {attributes: attrs}
    {name: 'Total Deaths', expression: 'number_dead', statistic: 'SUM' },
    {name: 'Total Injuries', expression: 'gis_incapacitating', statistic: 'SUM' }  ]);
return summaryFS;
RichardCreek
Thank you so much for your continued assistance Ken, I really do appreciate it. Unfortunately, received this error: Test execution error: '}' expected.. Verify test data. It doesn't like somethin with line 40
KenBuja
A few fixes I missed
// sets portal url
  var temp_dict = {
    fields: fieldList,
    geometryType: '',
    features: []
    for (var f in fs) {
    var attrs = {}
    Push(
      {attributes: attrs}
return FeatureSet(temp_dict);
var newFS = Memorize(crashFs)
return summaryFS;
RichardCreek
Thanks Ken for taking another look, received this error: Test execution error: Execution error - Key not found - date. Verify test data.
I don't see in the expression where collision_date (the date field) is referenced, maybe I'm missing something?
KenBuja
Two more changes. Line 8 should be
and line 25 should
attrs['collision_year'] = Year(f['collision_date'])
RichardCreek
Really close Ken, output is not counting the injuries though, looks like this.
gis_incapacitating is a string field (Yes or No) and needs to be counted for 'Yes' records and then summed
Current expression iteration for reference:
// sets portal url
  var temp_dict = {
    fields: fieldList,
    geometryType: '',
    features: []
    for (var f in fs) {
    var attrs = {}
    Push(
      {attributes: attrs}
return summaryFS;
