Arcade Expression for Dashboard - GroupBy and Calculate Mean
3155
01-04-2022 03:54 AM
DoZ
Hello everyone!
I am trying to summarize a table with data, and I am not sure how to proceed.
I have little programming skills 😞
I have to go from this:
DateCityN1N2N3
06.12.2021Munich5511
06.12.2021Berlin327
06.12.2021Hamburg339
14.12.2021Munich717
14.12.2021Berlin627
14.12.2021Hamburg5118
22.12.2021Munich127
22.12.2021Berlin147
22.12.2021Hamburg227
To a table where for every city AND for every day, the arithmetical mean between N1, N2 and N3 values is calculated. For example, for the City of Munich on the 06/12/2021 the mean of N1, N2 and N3 is 7 (=5+5+11).
 06.12.202114.12.202122.12.2021
Munich753,33
Berlin454,00
Hamburg583,67
I am really not sure how/when to loop and when to groupby
if anyone could help I would much appreciate it.
Thanks a Lot!
Dory
var fs = FeatureSetByPortalItem(Portal('https://www.arcgis.com'), 'xxxxxx' , 0, ['Date1', 'City', 'N1', 'N2','N3'], false);
var datefilter = Date(2020,12,31)
var fs_filt = Filter(fs, 'Datum_Meldung > @datefilter')
var fs_mean = {
fields: [
{ name: "Date1", type: "esriFieldTypeDate" },
{ name: "City", type: "esriFieldTypeString" },
{ name: "N_mean", type: "esriFieldTypeDouble" },
geometryType: "",
features: [],
var index = 0
for (var feature in fs_filt) {
fs_mean.features[index] = {
'attributes': {
'City' : ['City'],
'Datum': ['Date1'],
'N_mean': Sum(feature[....????)/3)
Tags (3)
jcarlson
It really depends on how you need to use the output. Is this for some report, or a dashboard?
The built-in GroupBy function should be able to give you what you need.
var group_exp = {
    expression: '(N1 + N2 + N3) / 3',
    statistic: 'SUM'
return GroupBy(
    fs_filt,
    ['Date1', 'City'],
    group_exp
One issue with the sample output table you've posted is that there is a new column for each date. While that is possible, it's not as nice to work with, and if you have many dates, can quickly become a rather unwieldy table.
Keeping the output of GroupBy will give you a row for each city/date combination, which can easily be visualized or further modified by other tools.
- Josh Carlson
Kendall County GIS
jcarlson
var group_exp = {
    statistic: 'SUM'
return GroupBy(
    fs_filt,
    ['Date1', 'City'],
    group_exp
- Josh Carlson
Kendall County GIS
DoZ
Hello Josh,
thank you so much, it worked perfectly. I copy down here my finale version.
Not sure how you can copy&paste the code here and let it look like the one in your answer, but anyway:
var fs = FeatureSetByPortalItem(Portal('https://www.arcgis.com'), 'xxxx' , 0, ['Date1', 'City', 'N1', 'N2','N3'], false);
var fs_filt = Filter(fs, 'Date1 > @datefilter')
var group_exp = [
{ name: 'N_Mean', expression: '(N1 + N2 + N3) / 3', statistic: 'SUM'}]
return GroupBy(fs_filt,['Date1', 'City'], group_exp)
return fs_filt
The graph looks like this
This is exactly the result I needed!
Thank you ao much,
Dory
