Arcade Expression Combining Multiple Layers For Graph in Dashboard
1711
03-12-2025 01:31 PM
Ian_Nelson
Hello, I'm attempting to create an arcade script that combines three layers (point, line, and polygon) with the same schema and then displaying that in a serial chart or pie chart. When I attempt to run the expression below the dashboard expression editor has this as the output. Any help would be greatly apricated! I've been staring at this for hours...
Thanks!
var p = Portal("https://maps.xyzxyzxy.com/portal/");
var point_field = FeatureSetByPortalItem(p,***itemid***,0,["Cat28Code2025","Notes2025","Ocondition2025","RBU"],false);
var polyline_field = FeatureSetByPortalItem(p,"***itemid***",0,["Cat28Code2025","Notes2025","Ocondition2025","RBU"],false);
var polygon_field = FeatureSetByPortalItem(p,"***itemid***",0,["Cat28Code2025","Notes2025","Ocondition2025","RBU"],false);
var combinedDict = {
    fields:[
        {name : "CatCode",type : "esriFieldTypeSmallInteger"},
        {name : "Notes",type : "esriFieldTypeString"},
        {name : "Condition",type : "esriFieldTypeDouble"},
        {name : "BusinessUnit",type : "esriFieldTypeString"},
        {name : "Source", type : "esriFieldTypeString"},
    'geometryType':"",
    'features':[], //create empty array for features
var i = 0;
//Loop through each FeatureSet and populate feature array
for (var m in point_field){
    combinedDict.features[i] = {
        attributes: {
            CatCode : m["Cat28Code2025"],
            Notes : m["Notes2025"],
            Condition : m["Ocondition2025"],
            BusinessUnit : m["RBU"],
            Source : "Point"
i++;
for (var m in polyline_field){
        attributes: {
            Source : "Polyline"
i++;
for (var m in polygon_field){
        attributes: {
            Source : "Polygon"
i++;
// Return dictionary cast as a feature set
return FeatureSet(Text(combinedDict));
RPGIS
by MVP Regular Contributor
Your issue is that you have this in your code trying to populate an array but it is set to populate a dictionary.
So you want to change it to look like the example below.
    var A = {
        attributes: {
            Source : "Polygon"
    Push( combinedDict.features , A )
I am also throwing this example in here to showcase a simpler manner to write the same code.
function CreateDictValues( InArray , InFeature , Fields , Geometry ){
	for( var row in InFeature ){
		var Values = iif( !IsEmpty( Geometry ) , { Source : Geometry } , {} )
		var Valid = False
		for( var field in row ){
			if( HasKey( Fields , field ) ){
				field = Fields[ field ]
				Values[ field ] = i[ field ]
				Valid = True
		if( Valid ){ Push( InArray , { attributes: Values } ) }
	return InArray
var PopValues = []
var F = {"Cat28Code2025":'CatCode',"Notes2025":'Notes',"Ocondition2025":"Condition","RBU":"BusinessUnit"}
CreateDictValues( PopValues , point_field  , F , "Point" )
CreateDictValues( PopValues , polyline_field , F , "Point" )
CreateDictValues( PopValues , polygon_field , F , "Point" )
    fields:[
    'geometryType':"",
    'features':PopValues ,
RPGIS
    var A = {
        attributes: {
            Source : "Polygon"
		var Valid = False
				Valid = True
	return InArray
var PopValues = []
    fields:[
    'geometryType':"",
Ian_Nelson
I was about to get both my expression and the one above to work. My problem was in the FeatureSetByPortalItem. I had the incorrect layerid. The zero needed to be 1
