Arcade Expression: Combine Multiple Layers
3258
07-14-2023 08:36 AM
dwold
I found this but I am not a developer and cannot really interpret and make it work for the data I want to use. I would like to combine two tables/attribute fields together.
Layer/Table names are Assessment and IndicatorAssessment.
I'd like to combine all fields but specifically, I need the Name field from Assessment and Lifeline, Component, Indicator, and Trend fields from IndicatorAssessment  in one new layer
I want to use that new data expression for an element in my dashboard
JohannesLindner
MVP Alum
The expression you found executes a Merge: Take two (or more) datasets with the same fields and copy all rows of those datasets into a new dataset.
What you describe sounds like a Join: Assign the rows of one dataset to the rows of another dataset (different fields) based on the values of a common field.
Can you please confirm which of these you want? Also, if you want a join, what is the common field?
Have a great day!
Johannes
dwold
@JohannesLindner I eventually got it to work. Thank you for your suggestions!
