Arcade Data Expression - GroupBy and Latest Sample Date
5368
10-26-2022 08:39 AM
HashemAbdo
am trying to create a cleaned up table that shows the most recent available date for each ['siteID','sys_phu', 'sys_sewershedName'] while still showing the associated COVID variant values [sys_estFreqReads_DeltaB16172,....).
My issue is that i am trying to show these fields that are associated with the GroupBy tool without running any calculations to the variants. Is GroupBy the right tool here ? Would some be able to help me ?
{name:'sys_estFreqReads_DeltaB16172', expression:'sys_estFreqReads_DeltaB16172', statistic:'MAX'},
{name:'sys_estFreqReads_OmicronBA1', expression:'sys_estFreqReads_OmicronBA1', statistic:'MAX'},
{name:'sys_estFreqReads_OmicronBA2', expression:'sys_estFreqReads_OmicronBA2', statistic:'MAX'},
{name:'sys_estFreqReads_OmicronBA4', expression:'sys_estFreqReads_OmicronBA4', statistic:'MAX'},
{name:'sys_estFreqReads_OmicronBA5', expression:'sys_estFreqReads_OmicronBA5', statistic:'MAX'},
{name:'sys_estFreqReads_OmicronBA275', expression:'sys_estFreqReads_OmicronBA275', statistic:'MAX'}
Code below
var portal = Portal('https://arcgis.com');
var fs = FeatureSetByPortalItem(
portal,
'XXX',
0,
'sys_sewershedName',
'sys_phu',
'sampleDate',
'siteID',
'lowQuality'
false
//create table
var fs_gp = GroupBy(
fs,
['siteID','sys_phu', 'sys_sewershedName'],
[{name:'sampleDate', expression:'sampleDate', statistic:'MAX'},
// Create array for holding features, feat object for populating array
var features = [];
var feat;
//var newdate2 = Text($datapoint["sampleDate"],'DD-MMM-YY');
// Populate feature array
for (var feature in fs_gp) {
// Console(feature['sampleDate']);
feat = {
'attributes': {
'sampleDate': Text(feature['sampleDate'],'D-MMM-YY'),
'siteID': (feature['siteID']),
'sys_phu': Text(feature['sys_phu']),
'sys_sewershedName': Text(feature['sys_sewershedName']),
'sys_estFreqReads_DeltaB16172': (feature['sys_estFreqReads_DeltaB16172']),
'sys_estFreqReads_OmicronBA1': (feature['sys_estFreqReads_OmicronBA1']),
'sys_estFreqReads_OmicronBA2': (feature['sys_estFreqReads_OmicronBA2']),
'sys_estFreqReads_OmicronBA4': (feature['sys_estFreqReads_OmicronBA4']),
'sys_estFreqReads_OmicronBA5': (feature['sys_estFreqReads_OmicronBA5']),
'sys_estFreqReads_OmicronBA275': (feature['sys_estFreqReads_OmicronBA275']),
'dow_num': Weekday(feature['sampleDate']),
'dow': Text(feature['sampleDate'], 'dddd')
Push(features, feat);
var dowDict = {
'fields': [
{ 'name': 'sampleDate', 'type': 'esriFieldTypeString'},
{ 'name': 'siteID', 'type': 'esriFieldTypeString'},
{'name': 'sys_phu', 'type': 'esriFieldTypeString'},
{'name': 'sys_sewershedName', 'type': 'esriFieldTypeString'},
{ 'name': 'sys_estFreqReads_DeltaB16172', 'type': 'esriFieldTypeDouble'},
{ 'name': 'sys_estFreqReads_OmicronBA1', 'type': 'esriFieldTypeDouble'},
{ 'name': 'sys_estFreqReads_OmicronBA2', 'type': 'esriFieldTypeDouble'},
{ 'name': 'sys_estFreqReads_OmicronBA4', 'type': 'esriFieldTypeDouble'},
{ 'name': 'sys_estFreqReads_OmicronBA5', 'type': 'esriFieldTypeDouble'},
{ 'name': 'sys_estFreqReads_OmicronBA275', 'type': 'esriFieldTypeDouble'},
{ 'name': 'dow_num', 'type': 'esriFieldTypeInteger'},
{'name': 'dow', 'type': 'esriFieldTypeString'}
'geometryType': '',
'features': features
// Convert dictionary to feature set.
//var fs_dict = FeatureSet(Text(dowDict));
return FeatureSet(Text(dowDict));
From the previous postings i feel like  @JohannesLindner is an ALL STAR with Arcade Challenges 🙂
JohannesLindner
MVP Alum
You have to do it in two steps:
  • Use GroupBy to get the MAX date for each site
  • Use a loop to fill your output featureset, filtering the input data
I hate filtering with date values with a passion, because any number of things can go wrong, and the syntax depends on your database. I would use Distinct() instead:
var p = Portal('https://arcgis.com');  // don't assign to names of functions!
    p,
    'XXX',
    0,
        'sys_phu',
        'sampleDate',
        'siteID',
        'lowQuality'
    false
// create output fs
var dowDict = {
    'fields': [
    'geometryType': '',
    'features': []
// get all distinct combinations of ['siteID','sys_phu', 'sys_sewershedName']
var sites = Distinct(fs, ['siteID','sys_phu', 'sys_sewershedName'])
for (var site in sites) {
    var id = site.siteID
    var phu = site.sys_phu
    var sewershed = site.sys_sewershedName
    // get all samples for this site
    var samples = Filter(fs, 'siteID = @ID AND sys_phu = @phu AND sys_sewershedName = @sewershed')
    // get the latest sample
    var latest_sample = First(OrderBy(samples, 'sampleDate DESC'))
    // null check to avoid errors
    if(latest_sample == null) { continue }
    // create the new feature and push it into the output fs
    feat = {
        'attributes': {
            'sampleDate': Number(latest_sample['sampleDate']),
            'siteID': latest_sample['siteID'],
            'sys_phu': Text(latest_sample['sys_phu']),
            'sys_sewershedName': Text(latest_sample['sys_sewershedName']),
            'sys_estFreqReads_DeltaB16172': (latest_sample['sys_estFreqReads_DeltaB16172']),
            'sys_estFreqReads_OmicronBA1': (latest_sample['sys_estFreqReads_OmicronBA1']),
            'sys_estFreqReads_OmicronBA2': (latest_sample['sys_estFreqReads_OmicronBA2']),
            'sys_estFreqReads_OmicronBA4': (latest_sample['sys_estFreqReads_OmicronBA4']),
            'sys_estFreqReads_OmicronBA5': (latest_sample['sys_estFreqReads_OmicronBA5']),
            'sys_estFreqReads_OmicronBA275': (latest_sample['sys_estFreqReads_OmicronBA275']),
            'dow_num': Weekday(latest_sample['sampleDate']),
            'dow': Text(latest_sample['sampleDate'], 'dddd')
    Push(dowDict.features, feat);
Have a great day!
Johannes
JohannesLindner
MVP Alum
    p,
    'XXX',
    0,
        'sys_phu',
        'sampleDate',
        'siteID',
        'lowQuality'
    false
// create output fs
var dowDict = {
    'fields': [
    'geometryType': '',
    'features': []
    feat = {
        'attributes': {
Have a great day!
Johannes
HashemAbdo
Hello Johannes, It worked !!!
You are amazing 🏆 !!
HashemAbdo
Hello  @JohannesLindner ,
I have one more question,
In some cases some SiteIDs will have two samples for the same Date and I would like both samples to be shown in the final product output. I was trying to see if another If statement that would see if the date in the latest sample date but it seems like Arcade doesn't let me do that. Is there another way of doing it ?
Something like that:
// samples
var sample_list = OrderBy(samples, 'sampleDate DESC')
if(latest_sample.sampleDate == sample_list[1].sampleDate )
latest_sample = sample_list[1]
Updated code:
portal,
'XXXX',
0,
'sys_phu',
'sampleDate',
'siteID',
'lowQuality'
false
var dowDict = {
'fields': [
{'name': 'dow', 'type': 'esriFieldTypeString'},
{'name': 'lowQuality', 'type': 'esriFieldTypeString'}
'geometryType': '',
'features': []
//var sites = Distinct(fs, ['siteID','sys_phu', 'sys_sewershedName'])
var sites = Distinct(fs, ['siteID'])
var features = [];
var feat;
//var phu = site.sys_phu
//var sewershed = site.sys_sewershedName
var samples = Filter(fs,'siteID = @ID')
// samples
feat = {
'attributes': {
'sampleDate': Text(latest_sample['sampleDate'],'D-MMM-YY'),
'siteID': (latest_sample['siteID']),
'dow': Text(latest_sample['sampleDate'], 'dddd'),
'lowQuality': Text(latest_sample['lowQuality']),
