Append tables in data expression
1733
11-04-2022 10:21 AM
RohitJaikumar
I am new to using Arcade expressions. I want a dashboard to aggregate data from 4 different feature layers into a table or a chart. The data has four maps with polyline feature layer representing each year 2023, 2026, 2036 and 2045. I was able to create aggregated data from individual layers by repeating the following code for each layer's data source.
var fs = FeatureSetByPortalItem(Portal('https://tamu.maps.arcgis.com'), '302880accba645198a5174df9f51b300', 3,['STREET','FAC_TYPE','NUM_LANES','MTP_ID'])
var agg = GroupBy(fs,['MTP_ID','FAC_TYPE','STREET'],[{name:'Lanes',expression:'NUM_LANES',statistic: 'MAX'}])
var agsum = GroupBy(agg,['MTP_ID','FAC_TYPE'],[{name:'Lanes',expression:'Lanes',statistic:'SUM'}])
return agsum
Ideally I want them in a single table which shows the number of lanes in each year for each MTP ID.  I am not sure which function to use to append  tables with arcade expressions.  Any help would be appreciated.
jcarlson
If all you need is to merge your tables together, you'll need to use loops and push the features into a single array. There's currently no easier way to get the features from one set out into an array, unfortunately.
var merge_arr = []
// repeat this loop for each of your grouped featuresets
for (var f in fs){
    Push(merge_arr, f)
// this assumes your schemas are all the same between layers
var merge_dict = {
    fields: Schema(fs)['fields'],
    geometryType: '',
    features: merge_arr
var merge_fs = FeatureSet(Text(merge_dict))
return merge_fs
There are probably some adjustments you'll need to make to this for your particular data, but this should give you the general idea.
- Josh Carlson
Kendall County GIS
RohitJaikumar
Thanks for the reply. I think the solution almost works. I think I have no idea how to repeat the for loop to add rows to the merge_arr. It only returns values for 2045 as that's the last loop. Here's what I have
var fs = FeatureSetByPortalItem(Portal('https://tamu.maps.arcgis.com'), '302880accba645198a5174df9f51b300', 3,['FY','STREET','FAC_TYPE','NUM_LANES','MTP_ID'])
var fs26 = FeatureSetByPortalItem(Portal('https://tamu.maps.arcgis.com'), '302880accba645198a5174df9f51b300', 2,['FY','STREET','FAC_TYPE','NUM_LANES','MTP_ID'])
var fs36 = FeatureSetByPortalItem(Portal('https://tamu.maps.arcgis.com'), '302880accba645198a5174df9f51b300', 1,['FY','STREET','FAC_TYPE','NUM_LANES','MTP_ID'])
var fs45 = FeatureSetByPortalItem(Portal('https://tamu.maps.arcgis.com'), '302880accba645198a5174df9f51b300', 0,['FY','STREET','FAC_TYPE','NUM_LANES','MTP_ID'])
var merge_arr = []
for (var f in fs){
Push(merge_arr, f)
for (var f26 in fs26){
Push(merge_arr, f26)
for (var f36 in fs36){
Push(merge_arr, f36)
for (var f45 in fs45){
Push(merge_arr, f45)
var merge_dict = {
geometryType: '',
features: merge_arr
var agg = GroupBy(merge_fs,['FY','MTP_ID','FAC_TYPE','STREET'],[{name:'Lanes',expression:'NUM_LANES',statistic: 'MAX'}])
var agsum = GroupBy(agg,['FY','MTP_ID','FAC_TYPE'],[{name:'Lanes',expression:'Lanes',statistic:'SUM'}])
return agsum
