Add Tabs to Operations Dashboard
9387
04-14-2020 01:18 PM
joerodmey
Can "pages/tabs" be added to operations dashboard? By this I referring to the ability to add new pages or tabs to the main overall ops dash layout. I want to have separate tabs on the same dashboard rather than separate dashboard. For example I want one tab for my map and a few indicator types. On another tab I want graphs and different indicators.
How do I accomplish this? Derek Law
Thanks
KenBuja
MVP Esteemed Contributor
If you drag an item over an existing item, you'll have the option to stack the items. This will give you tabbed items.
joerodmey
That's close. Based on your screenshots if I were to hit the serial chart tab the map would still stick around.
My goal is to have a map on one tab with a few indicator object types, the 2nd tab will have charts and more indicators. I want the tabs to act more like "pages".
KenBuja
You'd just stack the items on the map instead.
DerekLaw
Esri Esteemed Contributor
Hi Joe,
Ken's reply is correct. Here's the help topic for more info,
Dashboard layout—ArcGIS Dashboards | Documentation
(see stack elements)
Hope this helps,
