10.6.1 Operations Dashboard not refreshing data
1122
08-27-2018 05:38 PM
DanielJohns
We're now on 10.6.1 and I created an Ops Dashboard(OD) using some gauges and even a map (tied to a map service hosted through Portal). None of the widgets refresh against the services. I've republished, made a map refresh interval 0.1, but nothing appears to work. From what I can tell this has been an issue for a while. I've added filters and even new geometry to see if a non-filtered gauge would increase.
From what I read the desktop OD works with a refresh, but not the server hosted? Can someone provide either a solution or clarity on this topic?
Thank you,
Daniel
