ArcGIS Dashboards Questions
253
34.7M
3.2K
The message you are trying to access is permanently deleted.
| Open | It appears that when a chart is using multiple series, only the hover label of the primary series seems to be honorin... by DerekMStrout Frequent Contributor 0 0 | 0 | 0 | |
| Open | I’d like to propose an enhancement to allow the search tool within the map element in ArcGIS Online Dashboards to be ... by Laura 1 0 | 1 | 0 | |
| Open | I would like to propose an enhancement to ArcGIS Dashboards that would significantly improve temporal data visualizat... by GilCazaban Emerging Contributor 5 1 | 5 | 1 | |
| Open | We have several use cases for the need of a calendar element in Dashboards. The idea is that you would be able to fl... by MichaelSnook Frequent Contributor 2 0 | 2 | 0 | |
| Open | I'm referencing my question on color contrast here https://community.esri.com/t5/accessibility-questions/dashboard-se... by andeb31 Occasional Contributor 2 0 | 2 | 0 | |
| Open | Replicate the ExB 'Move to pending list' capability for dashboard widgets.In ExB I frequently use the Pending list as... by NeilWebber Regular Contributor 3 0 | 3 | 0 | |
| Open | When making a bar chart in Dashboards, the axis titles typically behave the way you would expect, where the y-axis ti... by Austin_Migchelbrink Emerging Contributor 0 0 | 0 | 0 | |
| Open | Some of the Dashboard widgets allow for dynamic text. The most obvious example is the list widget where you can use f... by NiklasNorrthon1 Emerging Contributor 1 0 | 1 | 0 | |
| Open | When there is a serial bar chart with many categories for a variable, it would be helpful for a user to be able to se... by Ellie_Linden Regular Contributor 0 1 | 0 | 1 | |
| Open | ArcGIS Dashboards spatial filters operate at the feature level, not the geometry level. When a line intersects a poly... by Miralem_Zeljo Frequent Contributor 2 0 | 2 | 0 | |
| Open | Please add a new graph visualization type to the ArcGIS Dashboard product. This visualization type may be or network ... by CoffeeforClosers Regular Contributor 2 1 | 2 | 1 | |
| Open | In a serial chart you have the option to enable "Zoom and scroll" in the category axis tab. The users love it to sta... by Scott_Sambell Frequent Contributor 0 0 | 0 | 0 | |
| Open | We’ve created a shared theme for our ArcGIS Online content, and it works great across most app types - except Dashboa... by EmileeFreeman Occasional Contributor 3 0 | 3 | 0 | |
| Open | Hello I had a possible suggestion. I would like to see a way to change the label for the button for the drawer widge... by durus5995 Occasional Contributor 0 0 | 0 | 0 | |
| Open | Allow for Tables in Dashboards to be sortable by values so users can see what combined features are of note when view... by rryan_edboec Emerging Contributor 4 2 | 4 | 2 |
Idea Submission Guidelines
| User | Count |
| 5 | |
| 5 | |
| 4 | |
| 3 | |
| 3 |
