Allow two (or more) value axes in Dashboard graphs
17045
28
02-28-2018 06:47 AM
Status: Implemented
AnninaHirschi_Wyss1
We have a client who needs to compare two types of attributes inside the same graph/chart.
This is already possible in the web based operations dashboard, but if the values are very different, e.g. one attribute value ranges from -2 to 4 and the other from 1000 to 5000 the graph just shows something like two almost straight lines on the bottom and top of the graph.
The units for each datatype need to be specified in the title/description of the graph instead of adding them to the Value Axis properties.
Basically this type of charts is also frequently used in climate diagrams to compare rainfall and temperature.
I mentioned this enhancement in the Beta Program, but it doesn't look like that it has been taken into consideration so far or if there is a chance that it may be implemented.
cc: jshaner-esristaffAPulver-esristaff
28 Comments
Teresa_Blader
Needed
ScottFortman1
Yes please add this, such a basic graphing functionality that I can't believe isn't there already.
Sara_Fatimah
I would also love the ability to plot a double y-axis graph for my traffic data. Thank you!
patrickb
LeAnnaKilhoffer
I would like to use this function to show lake profile data. I would like to be able to show the comparison of lake temperature and dissolved oxygen over depth.
TommyJackson
This should be more than under consideration!
mikaël
Secondary axis value is now available! 🎉
SandraLuken1
With the February 2025 ArcGIS Online update, serial charts when categorized by features now supports dual-axis.
