ArcGIS Connector Trigger Not Displaying Correct Feature Services in Power Automate
39
7 hours ago
CatHeindel
Hi everyone,
I'm running into an issue with the ArcGIS Connector in Power Automate and wanted to see if anyone else is experiencing the same thing.
When setting up a trigger that connects to a feature service, I'm noticing two problems:
  1. Not all eligible services are showing up — some feature services that should be available (and are owned by my account) are missing from the list.
  2. Services that shouldn’t be eligible are appearing — specifically, services that do not have "Track Changes" enabled are showing up as options for the trigger, even though they shouldn't be valid for that use case.
I'm using ArcGIS Online, and I've confirmed that the missing services are properly configured. Has anyone else seen this behavior? Is this a known issue with the connector or possibly a bug in the latest release?
Any insights or workarounds would be appreciated!
Thanks in advance.
