When using Collector for the first time to access web maps on our portal, I can't get past the url entry screen to login. What's going on here?
2446
8
12-20-2019 10:13 AM
KellyNeumeier
I type in the full url for our portal and hit continue and it doesn't go anywhere...no error message, just can't ever get a login screen.  Our portal administrator tested as well with no luck.
ios 13.3
Kylie
by Esri Regular Contributor
Are you using the URL to your portal instance? For example, https://myportal.mycompany.com/arcgis
Esri Education Team
KellyNeumeier
Yes.  Our portal admin tried as well with no success.
Kylie
What version of the app are you using?
Esri Education Team
KellyNeumeier
Collector for ArcGIS 19.2.0
Kylie
What version of Enterprise are you using, and do you know what kind of accounts you are using to connect?
Esri Education Team
KellyNeumeier
I now have reason to believe there may be an SSL issue with our portal.  Will research further.  Thanks!
Kylie
OK I'm glad you are making progress on it!
Esri Education Team
KellyNeumeier
Thanks!  I hope this is all that it is...
