Video Attachments - quality and length
2566
12-16-2013 09:15 AM
EricStetser
I am testing the Collector application on an iPad Air to capture locations and provide status updates.  I have noticed that the video quality is reduced when captured from within the Collector application.  I also believe that if you upload a pre-captured video, it is reduced in size/quality when posted.  Is there a way to manage the video quality?
Also, is there a maximum time limit or file size for a attachment video?
Thanks
Eric Stetser
RussRoberts
Esri Notable Contributor
Videos in the app will undergo some compression when they are being sent through the app as an attachment. The max video length is 10 mins. There is currently no settings available where you can change these settings.
Cheers
Russ
EricStetser
Thank you.  Please consider adding the ability for the user to configure image resampling or video compression based on their own needs.  I would recommend that the default is to allow the native size to be posted.  If the user has bandwidth limitations, they could then decide to reduce quality to meet their overall needs.
Thanks
Eric
