update failed: updates could not be sent
4449
11-09-2015 03:17 AM
simoxu
by MVP Alum
Collector responds with the above error when I try to update attributes in the related table.
My circumstance:
publish feature service on the on-premise ArcGIS server, register the service in AGOL and make a webmap using the service. the firewall between the ArcGIS server and AGOL is not a problem, as I can view the service from the public domain.
I tried to get more info of the error, so I configured Fiddler as a proxy for my collector, here is the request and the response I captured:
POST https://utility.arcgis.com/usrsvcs/servers/xxx-item_id-xxxxx/rest/services/DCSIExt/RIASP2_LOCSA_Port... HTTP/1.1
RESPONSE:
{"error":{"code":500,"message":"Unable to complete operation.","details":[]}}
I don't see the utility service in my AGOL settings at all.
Can anyone shed some light on it?
Thanks in advance
Miaogeng Zhang
simoxu
by MVP Alum
Problem solved.
It's in the privilege settings for my db account.
I found the issue when I looked into the logs on my server, there was a "SEVERE" error, with message:
"Error: Insufficient permissions [table name]"
