Symbology Reference Scale
3024
04-24-2014 01:24 PM
LuciHawkins
Is there a way to set a reference scale for symbology?  The symbols end up being way to small when we zoom in.  If we make them bigger, when we are zoomed all of the way out, they sporadically show up.
Luci
RussRoberts
Esri Notable Contributor
Currently there is no way for you to set up different symbols for different levels. If you are only viewing this in a connected mode I would say you could copy the layer and give the copied layer a different renderer and a set scale visibility. Offline does not support this right now so if you are going to use this and try to download the map it will probably fail to download.
Russ
RussRoberts
Russ
LuciHawkins
Thank you Russ.  We have played around with the symbols and are using the ArcGIS online symbols instead of symbolizing prior to sharing the service.  They seem to be working a bit better but we had to make them huge.
Luci
