ArcGIS Online Map and Data or ArcGIS Server
1751
04-17-2014 04:51 AM
LuciHawkins
We have just began playing around with Collector.  We are going to view one of the seminars today.  However, I was wondering if anyone had a link to some good information on how to use Collector with our own SDE geodatabase instead of ArcGIS Online.  Is Portal required to do that?
Luci
TimWitt
Luci,
I know functionallity has changed since this seminar was recorded, but it talks about Portal for ArcGIS and the collector app.
Hope this helps!
Tim
TimWitt
Luci,
Hope this helps!
Tim
IsmaelChivite
Esri Notable Contributor
collector requires either an ArcGIS Online subscription or Portal for ArcGIS. If you want to take your ArcSDE data into collector, you will also need ArcGIS Server.
  Have a look at this:http://resources.arcgis.com/en/help/main/10.2/index.html#//0154000006m1000000  and this: http://video.arcgis.com/watch/3474/using-collector-for-arcgis-with-arcgis-server-1022
Ismael
LuciHawkins
Thank you for the links.  We have ArcGIS Server and a subscription to ArcGIS online.  We do not have portal though and I do not believe we will be able to purchase the extension.  So, we will just work around it 🙂
Luci
