Several map services using one feature service
1165
06-25-2014 01:56 PM
KirkDavis1
I was curious about how ArcGIS Online & Collector handles feature services when they are used in several different web maps.  Will the adding of a feature (point data) to the feature service in a map service automatically populate the other web maps (which have the same feature service in it - and obviously synced)?  Ultimately, I want to create multiple map services that are identical (using the same feature service) so that my users can cache different areas in Collector and access them (different areas of the State) while working offline.
Hopefully there is a quick answer to this!  Thank you for reading this post!
Kirk
RussRoberts
Esri Notable Contributor
Yes this will work. You can create multiple maps and have them point to the same service and this will not cause any issue.
Russ
RussRoberts
Russ
