Setting Organisational URL as default
1601
6
05-20-2014 09:12 PM
GISSupport3
G'day All
Is there a way, now or planned, to have our organisational URL appear on start up?
Also a way to configure the background image?
Thanks again
RussRoberts
Esri Notable Contributor
The URL should be saved so when you log out of the application the URL will remain. There is no way to force the app the launch and have it grab a URL from another location.
Russ
GISSupport3
G'day Russ
We are not seeing that behaviour.
If we close out of the Collector app or turn off the device the previously entered Organisational URL reverts to http://www.arcgis.com
Regards
RussRoberts
Is this a Portal for ArcGIS URL or an AGOL org url? If its an AGOL org URL are you signing into just the www.arcgis.com URL or are you entering the full URL?
Russ
GISSupport3
G'day Russ
This is a Portal for ArcGIS URL
Thanks as always
RussRoberts
with the 10.2.3 release of the app I was not able to reproduce this issue. When i sign into a portal and sign out the portal URL is still displayed.
Russ
GISSupport3
G'day Russ
I have moved onto something else for now.
I'll have another go when some of things have lined up.
Ed
