Related tables in Collector as a list not page per record
444
07-12-2019 03:54 AM
MarkCooper5
Hi
I need to take a dataset out using collector to monitor the status of dwellings on planning applications. There is a poylgon dataset for planning applications and a related table showing each dwelling on that application so that the date construction is started and ended can be captured. If I use Collector, this creates a related record for each dwelling, which is OK for small planning applications. However, some have hundreds of dwellings on, which makes scrolling through the pages of related records unworkable.
I there any way that the related records can be viewed as a list view rather than separate pages (databases like Access can do this in forms)? Alternatively, is there a better way to collect this? The reason Collector seems to be most appropriate is that, due to poor signal in rural areas, the data needs to be taken offline.
