popup subtitle
1425
06-13-2019 12:12 PM
JaredPilbeam2
Hello, how do I lose what appears to be a subtitle ('1035243.583' in the popup box)? The number itself is from the attribute field called "Easting". I only want to see 'Post Number: 2610010'.
In the web map Easting doesn't appear in the popup:
WengNg1
It looks like you are on Collector Classic, the 'subtitle' field is controlled by the Display Field when you publish the feature service.
Worth noting that this field is not honoured in Collector for ArcGIS at the moment.
WengNg1
JaredPilbeam2
Weng,
It is Collector for ArcGIS, actually. Version 18.0.3. I should've mentioned that.
