EXIF limitation will still be there. You will have to use the stock camera app with location permission and then add the photos to Collector through the photo library.
Thanks for the good news, we badly need it!!
It seems 10.3.5 will be a very interesting update. particularly
It seems like this has been implemented. Going to try it today! Work with attachments—Collector for ArcGIS | ArcGIS
We have been using this for a while now and it has really saved our database and future work area downloads from overloading! Well done on this one Esri!
Just an fyi, the option to limit attachment size doesn't seem to exist on Android devices (at least on Samsung Galaxy S7).
I instead have the exact opposite problem. I want to take pictures from an Iphone on high resolution to meet the requirements. But it seems that Collector now compresses the picture size to a 500 kb. Any Idea how I can take pictures from an Iphone with a high resolution?
Hi Alban -- If the default isn't working for you, you can change the attachment size that the app uses in the settings (see Work with attachments—Collector for ArcGIS | ArcGIS for complete steps how). One of the options is "Actual" and it will use the full resolution photo.
