Multi Pick lists in Collector
1941
6
05-22-2014 10:32 AM
ThompsonsAdmin
Is there a limit to the number of attributes that can be collected/displayed in Collector? I made my domain with 15 attributes to collect, but when I get to the app there are only 6 displayed. How do I get to the rest?
Also - I added coded values in my domain, so that they user can only pick what I coded (for data integrity and searching database later on), how come I don't see this?
Thank you all for your time and help!
Becky
RussRoberts
Esri Notable Contributor
Can you send me your service and I can take a look and see if the service is missing any info.
Russ
ThompsonsAdmin
Hi Russ,
Sure - how do I? Sorry I'm pretty new to arcgis online.
Becky
RussRoberts
You can create a group and share the service to that group and invite Collector4ArcGIS into that group and I can check it out without having to make the service public.
Russ
ThompsonsAdmin
I have sent a request - thank you!
RussRoberts
Are you using iOS or Android? I did a quick test on iOS and I am seeing all the fields and domains listed.
Russ
ThompsonsAdmin
I was just about to write the same thing - not sure what I did, but it seems to be working, thank you for your time and help!!
Becky
